Charalampos Kontogiorgos
Coolermaster Hyper 212x 2nd fan suggestion
Sneakypuss    0
Delta TFC1212DE-PWM
https://www.amazon.com/Delta-TFC1212DE-PWM-120mm-Speed-Sensor/dp/B008NZSUPQ
make sure you are wearing noise cancelling headphones or earmuffs
jokes aside,
CM fan you could use;
MASTERFAN PRO 120 AIR BALANCE
https://www.coolermaster.com/catalog/coolers/case-fan/masterfan-pro-120-ab/
non CM
Scythe SY1225SL12H 120mm "Slipstream" Case Fan
https://www.newegg.com/global/au-en/scythe-sy1225sl12h-slipstream-case-fan/p/N82E16835185059?cm_re=120mm_fan-_-35-185-059-_-Product
