Jared Harkey Harkey
650w gold no power output?
Hey I just recently go the cooler master 650w Gold for my new build and I completed the build and went to turn it on for the first time and nothing happened. I took the power supply out because I used a voltmeter and nothing was getting any power. I tested that the cord to the wall outlet and the wall outlet were putting out power and they were, but the power supply did nothing at all, no fan movement, sound just nothing. Any help would be appreciated!
DianaC    0
Join the club...my MWE 750 just failed after less than 90 days.  I spent 2 hours troubleshooting, thinking something else had failed.  Finally tried an old 650W I had lying around and the PC booted first try.  So I have started an RMA process, I suggest you do the same, unless you bought it within the last 30 days, in which case you can return it to the vendor.
