Kenneth Ackerman
MC500M rgb/fan control panel sync with MoBo
Per instruction manual the onboard rgb/fan control panel connects to the motherboard via a four-pin sync-up connector.
The case I just received comes with a five-pin sync-up connector.
There are no instructions on how to connect this to a typical 4-pin rgb header on a M/B.  No adapter provided.  Phone calls to Cooler Master go unanswered.
Any ideas folks?  Thanks in advance!
