Almartor
Silencio S600 Radiator 240mm and ODD cage
Almartor    0
I have a bluray drive and I am planing to mount water colling with a 120mm radiator on rear and a 240mm radiator on top. I am reading I will have to remove ODD cage to mount 240mm, but in other places I read I "may" remove the ODD cage.
Will I be able to mount some 240mm radiators with some optical drives? if some radiator fits, I will buy the onw which will fit.
or I cannot mount both in ANY case? In that case I will have to go for another case but I really like this one and I do not find any similar case with ODD drive.
Thank you
