I want to use my laptop to program the cool master argb/fan controller and need to know If I plug the usb into my usb port on my laptop can I access the controller that way, also I would like to use my fluid temp to controle fan speed and need to know if I splice a liquid probe onto the case probe can it use the fluid temp instead of the case temp. I am cooling on a wet bench and do not have a mother board to use with a header rail. side note if I disconnect the usb cable will the controller still work or dose it require the computer.
thermaltake 650 powersupplie
thermaltake c360 kit
alphacool apu block
1 set xspc msi z87 water block
1 Byrski dual channel waterblock
thanks for all the help
Edited by david mcgillivray
more info
