Thimo
the rgb on my ml360r does not seem to work
Thimo    0
so recently i bought a masterliquid ml360r to go with my new case. while the fans and pump are working perfectly fine, the rgb doesnt seem to light up. I've installed everything as they did in a instruction video, but it still wouldnt light up. Does anyone here know what might be the issue?
tai2go    0
Im having the identical problem...help would be great indeed.
My mobo is the Z390 Carbon from MSI. Followed the guide on youtube from Coolermaster on how to plug all the cables, lights on controller are on. Tried all the different USB ports on the mobo. Help. please....
Raphael    0
exact same problem but with a MB520 RGB.
front fans work but no lights.
try to install the light controller from this link https://coolermaster.egnyte.com/dl/vsv4rmcXjL/ but i get the same error as :
On 10/27/2019 at 8:29 AM, Grayson said:
exact same issue here combatibilty issue but you cant fully see the message
interested in an answer :)
Joe0121    0
I am having a similar issue on my 360RGB
Pump outer ring works fine, one of the fans work ok but it kinda flashes sporadically no matter what mode it's on. The other two fans dont light at all and if tried them in different ports on the controller. the issue def seems to follow the fan not the port on the controller.
Troy    0
contacted support regarding this and I was basically told to go find the answers here???  Seems as though there are no answers. lol I have the ML360p and everything works great other than 1/2 of one of the three fans light up.
