M1tch
Front Fans connector
M1tch    0
Hi Everybody,
I just built a pc config and it was no adapter provided with the case (MB 520) or the MB to connect the 3 in 1 connection from the front case fans.
Could someone telle me what I have to purchase as connector to plug it on the 4 pins MB fan pins? Is it a kind of Molex plug ?
Joined is a picture of the wire with the connector : 2 big male pins.
Thanks to all
Edited by M1tch
You connect the plug to an available female power supply. It is to power up the fans. In order to power the rgb lighting, you connect the 3 n 1 connector to your motherboards rgb header (it should be labeled as such). It is similar to the fan headers, and  it should have four or five pins. If your motherboard doesn’t come with an rgb header, then you need to buy an rgb controller. I am looking for one with a remote, as my motherboard doesn’t come with the header. The fans will still work if you plug in the two prong connector to your power supply, but there won’t be any lighting.
