AnTe
[MB530P] No RGB led fans with Gigabyte motherboard
AnTe    0
Hello everyone,I recently bought an MB530P case, having a Gigabyte AB350-Gaming 3 motherboard I thought I could plug directly the RGB fans to it to control their colors thanks to RGB Fusion since  they are compatible. But I can't connect the "Gigabyte" cable to my Gigabyte motherboard (I only have a 4-pin connector , "LED_C1" and a 5-pin connector "LED_C2"). Does this mean that my motherboard is actually NOT compatible with the case and that I have to buy a RGB Controller?? Or is there an other way?5fmOuJx.png7d1YROm.jpg
Update: OK, so after a lot of research I discovered that the Gigabyte AB350-Gaming 3 IS NOT compatible with ARGB fans, only with RGB fans, so if you are in my case DO NOT CONNECT THE 3-PIN CONNECTOR TO LED_C1 DESPITE WHAT SOME PEOPLE SAY or you might end up like me with 3 half fried fans who only show a feeble tint of blue :/
Edited by AnTe
Update
