Bryan McLeod
NO RGB lights for MB520.
I have an MSI B450 Gaming pro carbon AC motherboard. I'm trying to get the RGB fans on the MB520 to work. I don't have the controller. How do I power the RGB on these fans. I can't figure out how to connect the reset switch to it to operate it. Can someone please help.
I'm about to get my mb520 this weekend. Apparently the mb520 should come with a 1 to 3 splitter and a rgb controller for you to connect from 3 fans to your reset button. The same goes for your motherboard but your motherboard would need to have a rgb header for you to control the fans through software. At least that's what I've researched.
