CM Michiel    15
Hi Rodrger095257,
Do you have connect the RGB fans with the RGB Splitter cable to the RGB header on your motherboard?
I am having the same issue but I don't have an RGB header on my motherboard. I want to know if I can still have the RGB fans work without any extra stuff.
Mohd Noh    29
I am not sure too
Try check this link Non RGB Motherboard with RGB stuff
Connecting the power supply plug will allow the fans to work but if you want lighting, you will have to buy an rgb controller anywhere from a simple one for about 10 dollars or ones with remote for about 30. If you don’t get a remote you will control the colors through software on your motherboard providing it supports your motherboard through the bios setting.
