2tired2care 0 Posted May 26 Hello, I purchased the Cosmos 25th Anniversary full-tower case and I have a few questions. Firstly, I see that I can put up to three 120mm case fans on the top, but the radiator support section of the manual says the max size is 320mm. How is this possible if I can combine three 120mm fans (3 * 120 = 360)? Secondly, what is the max size radiator that can be mounted in the front? Lastly, how do I remove the ODD cage and HDD cage to make more room in the front of the case for airflow? Thank you in advance for your time and help! Quote Share this post Link to post Share on other sites
Randell Cocjin 0 Posted November 4 any luck if you have removed the ODD cage? Quote Share this post Link to post Share on other sites
