Shootist
C700M: Fan and RGB Controls Not Working
Shootist    0
Hi
I bought a C700M recently and am using it for a new rig.
The system boots up fine, but I have not been able to get the case lighting to work.
I have currently plugged the following on the fan/RGB controller PCB:
- 2 x SATA power to PSU (using 1 cable)
- 1 x 3-pin ARGB? header to the ADD_HEADER outlet on the mobo (using an ASUS Maximus XI Formula)
- 1 x fan header to the CHA_FAN3 outlet on the mobo
The RGB and fan controls on the front panel are all lit up throughout. Pressing them does nothing.
Am I connecting something incorrectly or?
Edited by Shootist
Update: Fans are working now, but controls still don't
Shootist    0
22 hours ago, Deniz Roth said:
U conected the cable for the Buttons Too the Controller?
I believe they came pre-connected in the case
