Chris Flannigan
Hyper 212 LED Turbo not able to be mounted vertically on AM4 board
I bought this cooler as it was mentioned to be AMD comparable, however the supplied AMD bracket only allows the cooler to be mounted in the horizontal position (see attached photo). As I have no top vent all the cooler can do is move hot air about inside the case and is not suitable for use in the current position. I see that on another thread http://community.coolermaster.com/topic/21998-hyper-212-led-turbo-not-fitting-correctly-on-am4-board-solved/page/5/ that there is a fix for this but want to know how I go about getting one of these brackets. I'm really disappointed in the product.
