GPNterprises
Hyper 212 RGB Connection to Motherboard 4 pin
WIN 7 Ultimate. . P8P67 motherboardFollowed install instr. Replaced original CPU fan. On boot-up the BIOS did not recognize that a CPU fan was present and prevented boot-up. Changed BIOS to ignore CPU fan, boot-up successful. Now that the BIOS configuration has changed, Computer will not go into Sleep mode and stays on. Can force Sleep mode. There are 2 4 pin connect points at the motherboard and I plugged the fan into the original fan connection.
Other than the BIOS issue, all works fine
Do you know how to correct this?
