BillBo
Fan LED Controller C700M
BillBo    0
Hi,
I have two SATA ports on my fan / LED controller, both need two to be connected or one is it enough?
Thank Hi,
Tony B    0
I was wondering if they had software for the controller and also can my motherboard control it through the fan header?
neno    3
Well for the software part they are still working on it last time I was in contact with CM support, beta Masterplus software is still in beta and is missing C700M support. You can controll LEDs with your MB (beside case controller) if it's got aRGB connector (3 pin) and for controlling fans you can connect controller MB Sync connector to MB fan connector (PWM). Hope this helps.
