Vlad
MA610P LED (RGB) won't work
Vlad    0
Hello!
My motherboard - MSI B150M - does not support 12V RGB connections, so I have to use the controller included in the cooler package. The problem is that LED does not work. I tried connecting it to 3 different molex ports. Fans are working perfectly, however. Searched for solutions on the web, inc. forums, but did not find a working one. By the way, PC case's LED lighting is also connected to the same molex (after the ma610p controller) and work without any issues.
