David
C700M - Fans build help
David    0
Dear all,
I would like to put following settings for cooling:
Top: 3 x 140 Fans
Front: 3 x 140 Fans
Rear: 1 x 140 Fans
Bottom: 3 or 2 x 140 Fans (?)
But I saw only 6 places on the hub. Where is the 7th? If I would like to set bottom fans how could I put the fans on the hub?
Should I use Y cable in order put 2 fans on 1 place?
In order to put bottom fans must I use the same bracket than top bracket?
Thanks in advance for your help
David
Neni    3
For more then six fan you need to use y-splitter because there are only six fan connectors. But you should pay attention to the fan wattage. I believe you can connect MAX 4.8 Watts PER CHANNEL. And yes, for the bottom fans you need to use the same bracket as for the top and front fans, only you need to buy that separately 'cause you get only two included with the case. Currently cmstore in EU is out of stock for the bracket, and he next stock should arrive in about 2 months.
David    0
Hello Neno
Thanks a lot for your return!
It's great to have answer clearly explain :)
David
