Nathan
Cooler Master - Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler
Nathan    0
I just ordered this cpu cooler off of newegg and can't get the colors to change. I tried plugging in the separate controller instead of connecting it straight to the motherboard but then didn't get any lights at all?
CM Michiel    13
Hi Nathan,
Did you also connected the power supply molex cable to the RGB controller so the controller receives power? :)
WIN 7 Ultimate. Followed install instr. Replaced original CPU fan. On boot-up the BIOS did not recognize that a CPU fan was present and prevented boot-up. Changed BIOS to ignore CPU fan, boot-up successful. Now that the BIOS configuration has changed, Computer will not go into Sleep mode and stays on. Can force Sleep mode.
Did you get an issue like this? Do you know how to correct this?
Following the wiring connection instructions. Everything worked as it should after I reset my BIOS.
