Robb
Will this case (MB510L) work?
Robb    0
I have a MB510L case, and am considering purchasing a CM ML240R cooling system. Will this fit in this particular case, or should I have gotten another case?
CM Michiel    12
Hi Robb,
That will be no problem at all, the MasterBox MB510L is compatible with 240mm radiators ;)
MasterBox MB510L:
Liquid Cooling Support Front: 120 / 140 / 240 / 280 / 360mm (75mm clearance)
Top: 120 / 240mm
Rear: 120mm
