SeanG
CoolerMaster HAF 932 replacement case fan
SeanG    0
I have been a very happy customer for several years now of a HAF 932 case.  The side fan has gotten increasingly louder to the point that it needs to be replaced.  Is there a standard replacement fan sold by coolermaster or another brand folks would recommend?
The specs are:
Side: 230 x 30 mm standard fan x 1 / 700 rpm / 19 dBA (supports 120 mm fan x 4)
I can find a lot of 200mm fans online, but am not sure if they would fit the case for screwing in.  Also, do you recommend a CM replacement or another brand?
Thank you in advance for any help.
