Patrioten
Is 4-in-3 device cooler compabitle with Antec 1080AMG?
Patrioten    0
I bought the 4-in-3 device cooler and when I tried to install it, it seems it's not compatible.
The place I bought it from, it said on their website (styggapojken.com) that you needed 3x5.25 places but on the actual box of the 4-in-3 device cooler it says you need a 5.25 drive bay....
So...MUST I have a 3x5.25 drive bay?
Is it compatible with my case? If it is, how do I install it...? manual doesn't help.[/b]
Dark-Rain    0
The "Stacker" 4 in 3 module is designed to fit into the Coolermaster Stacker Case with the sliding rails, i wouldn't be suprised if it doesn't fit into your Antec case mate :lol::o:D:P
In other news it is designed to fit into 3 5-1/4" drive bays (the ones your cd/dvd/control modules fit into)
Patrioten    0
But it says "Cm stacker and other cases :x
Argh! 17$ down the dripper....argh again!
Oh well....seems I have to go buy something else....
Guest Mindless Moron
it'll fit take the plastic rails off and screw it in, :) even if the screw holes didnt line up ever heardo f a drill and self tapping screws?
