vishnuvardhan
CPU is running at 100 degrees Centigrade
Cooler Master MasterLiquid ML120L is not working as expected. I have bought it a month back, from day one onwards the product is performing so bad (CPU Temperatures used to reach until 85 C). Now the situation got worse as my CPU is getting heated until 100 degrees centigrade with CPU Cooler installed and working properly.
I am not sure how to check if the cooler and pump is working properly or not. Does anyone have the same problem?
