Adam Kitchen
Cooler Master - Hyper 212 Evo Compatibility
Hello
I am building a new Kaby Lake socket LGA1151 based PC for a friend of mine and I'm looking at using the CM 212 Evo since I've had success with it in other older Intel builds. The specs for the 212 Evo don't specify 1151 support. Does this cooler fit on LGA 1151 boards or do I need to look elsewhere for another cooler?
Thanks
CM Michiel    13
Hi Adam,
Yes the Hyper 212 EVO cooler is compatible with socket 1151 ;)
Specs Hyper 212 EVO:
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
CPU Socket Intel® LGA 2066 / 2011-3** / 2011** / 1366 / 1156 / 1155 / 1151 / 1150  socket
AMD® AM4* / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
