bluemanchew
Portal says "no cooler master device found" mh752
DarKnight    1
Posted (edited)
It's Normal It Should Detect as Keyboard Device        "Firmware/Drivers are Correctly installed in Your Controller Don't Worry"
On 5/2/2020 at 4:30 AM, BigGizmo said:
I'm having a same issue whit my Addressable RGB Led Controller  "MFP-ACBN-NNUNN-R1"
I think in my case it has some thing to do that windows is not installing the correct driver for the controller,
it shows up as a keyboard device and no info shows
how is it the controller showing up by you guy's???
or how did you guy's get it fixed?
Edited by DarKnight
