bluemanchew
Portal says "no cooler master device found" mh752
I am having the same problem but with my case fans! RGB LED controller says to plug in my cm device to get started and master plus portal says it can't detect a cm device either.
Mohd Noh    29
can you attach some picture regarding all of this ?
Matt W    1
I am having the same trouble with the RGB controller not being recognized by the software, ive tried it on 2 motherboards only to see the same problem saying it cant detect any compatible devices. I have my AIO that the controller came with, along with all my case fans and one rgb ssd plugged into the controller and i cant get it do see anything.
  • Upvote 1
