nolbear
Masterbox Pro 5 RGB: Front panel fans not lighting up the same color
nolbear    0
Hello people, first time poster here looking for a little help.
I recently built a custom PC with a Masterbox Pro 5 RGB and an ASUS Prime Z390-A motherboard, and I'm using ASUS Aura Sync to control the RGB lights. The 3 front panel fans are lighting up, but for some reason the colors aren't syncing up. Either one or two of the fans will display the correct color (the same color that the mobo lights up), but the others are different. For example, if I set the color to red, the top fan will be red but the other two are a blue-green color. If I set the color to green, the top fan will be green, and the bottom two are a pinkish color. If I set the color to blue, the top fan goes dark and the bottom two are blue.
Does anyone have any ideas why this might be happening? I think I connected everything up properly, but I'm relatively new to PC building so I could have made a rookie mistake. The LEDs are connected through a 3-way splitter to one of the RGB headers on the mobo (I made sure to plug it in with the arrow on the correct side) and the power is connected to a peripheral cable from the power supply.
Let me know if there's other info I can provide to help diagnose the issue.
I'm attaching a couple pics of how it looks when I set the colors to both red and blue with Aura Sync.
Il Morro    0
Hi'
The same thing happened to me and I thought I Will share the solution with you. RGB Leds have a polarity' so you have to make sure you are connecting them the right way. There is a triangle on the fan and one on the controller. Try to match them and if this doesn't work, try not to match them, this worked for me.
Home I helped you.
