Nooks55
MB 511 RGB built in case fans - how to turn them off or set the RPM?
Nooks55    0
I recently purchased an MB511 RGB case, which has 3 front facing fans, however I can't seem to control the RPM (or disable) these fans. I can only see the CPU fan and the rear fan in the BIOS. Is there any way to manually control the front facing fans?
Luís    0
Tell me each model number behind the 4 included fans. You should connect the rear fan to the motherboard and the 3 front fans to a splitter that goes also in the motherboard. Is the splitter 3 or 4 pin? You can photos of the fans and splitter if you want
