fuandy
master plus can't control mf120r argb fans
fuandy    1
I just got my mf120r argb 3 in1 pack. I connected everything just according to this video:
While I could control the colours thru as rock polychrome(i have asrock b450m pro4), but the master plus software won't recognize my fans. Then I used my own micro usb cable to connect the mini controller to a usb port on my pc, and then I could get the master+ to recognize the fans, but I still couldn't use the software to control the color. The software will recognize the fans, but can't control it.
HELP!!!!!!!
thanks
  • Upvote 1
chriscluny    1
I too have this issue, and the firmware update did not work.  Do I need to press any buttons on the controller to change from manual mode to USB control?
  • Upvote 1
