BornSlippy
H500M rgb question
BornSlippy    0
I have a question about the rgb controller of the h500m case. I read in the manual the power is supplied by a sata connector with an input of 5v and 12v. The 2 argb headers have 4 pins each. I think that means they have an output of 12v but i'm not sure because i've read that argb uses only 5v and 3 pins.
Thing is, i want to connect the ek-xpres 140 revo d5 rgb water pump to that 4 pin header but that's just normal rgb and not argb.
I don't want to fry the rgb controller so i'd like to be sure and i'm quite new to the whole rgb thing.
Note that i don't have a rgb header on my motherboard. No point in upgrading yet just for an rgb header.
