PCGUY
H500 Case Modification
PCGUY    0
I just got the H500 case and noticed the openings for the 200mm fans are restricted.You loose about 50% cooling from those 200mm fans. The case is made for 3 120 fans without any opening loss..I will open up the full 200mm openings by cutting away the case material...Since I will place my 240 liquid cooler at the top of the case I don’t require the front for any other fans. Also I will shorten the PS shroud just enough to hide the PS. I also removed the HDD tray since I use m.2 drives , and might cut another 140mm fan hole in that location to help cool the GPU card. Cooler Master should modify the case so by default the case is optimized for the 200mm fans, and a separate plate can be fitted for use of the 3 120 fans or Liquid cooler. Thanks....I would like your opinions...The PCGUY...
Edited by PCGUY
Photos added
PCGUY    0
Components
COOLER MASTER H500 MODDED CASE
ASUS TUF Z390 GAMING PLUS WIFI
CPU 9600K OC TO 4.6 MHZ
G SKILL RIPJAWS V SERIES 16G DDR4 3200
EVGA SUPERNOVA G3 750W PSU
SAMSUNG 970 EVO M.2 2280 500G SSD
COOLER MASTER ML240L RGB AIO COOLER
GIGABYTE RTX 2060 GAMING OC 6G 192-BIT DDR6
LG 28IN 4K MONITOR
FINAL RESULTS.....CPU AT IDLE 25C ....AT FULL LOAD PLAYING BATTLEFIELD 5.....MAX 42C...
NOISE LEVEL.....AT IDLE  ALMOST INAUDIBLE...AT FULL LOAD YOU HERE A LOW HUM FROM THE VIDEO CARD FANS RAMPING UP.
I HAVE ALLWAYS MODDED MY PC CASES AND NEVER HAD ANY COMPONENT FAILURES FROM HEAT ISSUES..THIS CASE HAS BEEN THE BEST ONE SO FAR DUE TO ITS  2 MASIVE 200MM FANS IN THE FRONT.
I WILL BE TWEAKING THE GPU AND CPU OC SPEEDS AND POST SOME BENCH RESULTS FOR TEMPS...
Edited by PCGUY
Added photos and text errors
Agent Donut    0
I have this case and instead, i just mounted the 2x 200mm fan inside the case, rather than outside. Did notice an improvement in airflow. Im now panning on doing the same thing you did. Can you tell what were your temps before doing the mod?
