Brenda Blair
Have H500P case and controller, need help
I have written to support two days ago and have not received a reply.  I have a Cooler Master H500P case and trying to hook it up to the ARGB controller as I bought the case second hand and the one that goes with it was not included. The ARGB is 3 pin and case fans have two hookups, one for power and one for lights, they are 4 pin. Second my MOBO is ASUS M5A97. First problem, The pins that are included with the case are so large there is no way for it to fit on the MOBO without breaking off the tab on the MOBO. Secondly, the ARGB controller wires that came with it will not work with the Case either since the fans have two sets of wires. Any Suggestions?
On 1/13/2019 at 4:09 PM, POCKATA said:
Wait, isn't the H500P with RGB fans? I thought only the H500M had ARGB fans.
Yeah, the H500P has two RGB fans pre-installed.
Create an account
Register a new account
Sign in
Sign In Now
