mauricio
rgb controller and wraith prism, can't sync color cycle timings
mauricio    0
Basically, i had the masterfan pro rgb kit, wich included an rgb controller, then i purchased the wraith prism heatsink, after installing i found out that cooler master makes the rgb software for it, and both interfaces from the prism and the rgb controller are very similar.
My trouble comes on the color cycle mode, both softwares have speeds from 1 to 5, and both speeds are very similar, but just a tiny bit faster/slower from each other, so, while when i turn on my pc, they are in sync, as time passes, it desyncs purely by timing
Is there anyway to make al fans sync perfectly? preferably by software, i tought i could get rid of the problem by connecting the rgb header to the controller, but the ring looses its default color mode
Create an account
Register a new account
Sign in
Sign In Now
