Joe
Masterbox MB530P front fans lights not working
Joe    0
Hi all,
I got a MasterBox MB530 case, and I must say is by far the best case I have owned so far. But I am frustrated because I cant figure out why none of the 3 front fans lights are working. The are powered and spinning just fine but I can't the EGB lights to work. And that was one of the reasons for choosing this case.
Each fan has 2 set of cables coming out of them: one to power the fan, and another to connect and sync the RGB LEDs with the mobo.
All 3 fans power cables are connected to a 3x1 molex power connector. No problem here. Connect this cable to the PSU and they run just fine. Also, all 3 fans are connected to a 3x1 RGB splitter cable. This is to sync RGB colors with your mobo if you want.
So, in my understanding, RBG lights should turn on just by powering the fans. You should be able to control the fans colors with the RGB button in the front panel without connecting them to the mobo. In other words, they should light up by just powering them.
Am I doing something wrong here. I will appreciate any help or advice on this.
Thanks!
Nicole    1
Update: The SATA power cable coming from the front panel looked bigger than normal to me and it didn't occur to me to attach it to the PSU via a SATA power supply cable. This cable is indeed the same that you use for a HDD. I simply connected this cable to the PSU and the power button light lit up. You then just simply take the 3x1 RGB splitter cable, hook it to all the fans and then there is one similar cable left coming from the front control panel. Attach the end of your 3x1 RGB splitter cable to this remaining cable and your fans should fully work. The fans spinning action is totally separate from the power required for the RGB. I feel like an idiot because I originally missed that SATA power supply cable and had no idea where it was supposed to go, but in the end I'm very happy with my purchase. This case looks awesome in person, especially now that it's finally working as it should. Lol : ) The directions that came with it really could be much better.
Original post:  I am having the same exact problem. I do not have a RGB header on my mobo, but was under the impression that I could still control the RGB fans by the button on the front panel. Not to mention, it says that an RGB controller is included, which I'm assuming is built in on the front panel because I did not receive a separate RGB controller. Having an RGB controller would mean that I should not need an RGB header..... just power to the RGB components....correct? Sorry I'm kind of a newbie.
Edited by Nicole
Update
  • Upvote 1
Bruce    0
Could you post up pics of your solution?  Because I thought I connected both the fan and rgb cables to the PSU, maybe a picture of your wiring for that would help me.  Thanks
Joe    0
Hi Nicole, thanks so for the detailed explanation.
In my case, the fan power connection is a molex connection. Plug that to the PSU and the 3 fans spin without problem.  The Sata connection if for the RGB light on the case front panel button. Both are connected to the PSU. So I have power in all 3 fans, and RGB light in the case front panel button. No problem there.
The issue is with the fans RGB part.
For the RGB part, all 3 fans are connected to a 3x2 splitter (sorry my OP says is 3x1 when is actually a 3x2 splitter):
3 RGB inputs from 3 case fans are connected to this splitter. 2 cables comes out: 1 is labeled as compatible with Gigabyte, and the other is labeled as compatible with ASUS (my mobo is ASUS), Ashrock and MSI.
Then, there is the cable from the case panel. A 4 pin (only 3 with connector pins) male cable. This was factory connected to the  4 pin ASUS labeled cable going out from the RGB splittter. When connected, there s is no RGB light in case panel button AND fans. When disconnected, there is RGB light on the case panel button BUT NOT on the RGB fans.
I will take some pictures and upload here later so you can all see what I mean.
Hope I can solve this, because the case without those 3 RGB fans lighting up looks...not that good.
Best, regards Joe.
Edited by Joe
Editorial corrections
Joe    0
Dear Nicole,
Unfortunately, the instruction I received with my MB530P, were printed with invisible ink on non-existent paper...
Thank you SO MUCH! I will never forget you for this! ;)
