Maple
Problem with the conectors.
Maple    0
Hey everyone, i recently bought Cooler master's MA410M air cooler or my cpu. Everything was going perfectly until i was stuck with a chord which was supposed to be a 4 pin/3pin (4 pin for ASUS as intended in the manual) Although these conectors can not fit anywhere in my motherboard apart from the RGB headers which are 4 pin.I have an ASUS PRIME X470 PRO. Below i will attach some photo's. The cable i have problem with is cable N (on the manual) . Can you tell me if i recieved a wrong pair of cables or if i am dumb and if i am indeed dumb where do these go. On the photos attached the pin on the top is supposed to be for ASUS and the one below for gigabyte. An other problem is that AURA sync does not recognize the Air cooler but that is probably because of the missing cable.
I am in the same boat as you. I see that your post is dated from the first of the year. I can't believe that nobody has gotten back to you. I will search the forums and see if I can find a resolution.
