Ben Cummmins
CoolerMaster MasterBox Lite 5 RGB Fans don't light up
Case came with 3 rgb fans at the front of the case and those 3 fans where linked to a coolermaster adapter which brought it down to just one lead. i've plugged that lead into the motherboard aswell as another cable involving the fan which i plugged into a molex cable straight from the psu, but i have no clue how to turn on the rgb lights or anything
I'm having the same issue on the MB520 fans speed is controlled seperate from RGB for me. I pluged a fan rgb into my motherboard header and it works checked the power to the rgb controller thats good the item that appears to be the problem for me is the RGB controller.
Hello,
can you find model no. of fans?
Thank you
Edited by stonowinnerz
