Chuck Gulotta
MA410M with Aorus Z390 Pro Wifi
Can I connect the ARGB directly into the header on the motherboard?  I want to control the LED's with the Motherboard utility, not the controller box.  If I can, what voltage would I set the ARGB to, 5V or 12V?  Also, can I plug the Thermistor header directly into the temp header on the motherboard? The pins appear to be a slightly different spacing or diameter.
Thank you
