RowanT
Compatibility between motherboard and case ( M5A97 2.0)(H500P)
RowanT    0
I have recently gotten the H500P Midtower and I noticed the front 2 RGB fans arent working when I plug it in and turn it on.
Just wondering if its even compatible with my motherboard M5A97 2.0
mcm-h500p-mgnn-s00, is the model of the case
Mohd Noh    29
Hello
What you mentioned above is compatible  > Motherboard Dimension and Chassis will FIT , Because you board is ATX type and the chassis is support up to E-ATX type board
But the problem is > no RGB will ON ok .. due your board is out to dated already and try refer this link : Non RGB Motherboard with RGB stuff
