Peter
USB3 Voltage exceeded.
Peter    0
Hi Guys,
I recently removed a cable from one of the front panel usb3 plugs & it pulled out the gray coloured tab that protects the metal tabs. End result is I got a voltage exceeded message on the screen.
I have rebooted the computer & neither usb port works. The rear usb plugs all work fine.
1. Have I stuffed the 2 ports & is there a replace part available?
2. Case was purchased Dec 2017 so is this a warranty claim?
IMG_20181227_144851192.thumb.jpg.222bc017c60ec44de8c9b282698c791e.jpgIMG_20181227_144904764.thumb.jpg.74219865499c889a50ed82edfcc062f4.jpg
