Gushy
POWER LED missing
Gushy    0
Hello,
i have client that buy Trooper SE chassis,
And motherboard Asus Maximus XI Code.
Here the problem is,
+POWER_LED- cable on trooper chassis missing!
How i suppose to make the motherboard even start working ?
Something must tell the motherboard that Power button is press ON.
I try everything and noting work.
Also there is some weird looking cable which there is no schematics what it does.
User-added image
That fan cable is for fans i see, but i have no idea where on motherboard need to be plug in.
I will keep researching cuz i need that pc working.
I hope you guys gave me the answer if possible with photos or scheme.
Thank you in advanced.
 Merry Christmas Eve to everybody!
Same problem here. The PLED/PWR_LED (Power LED, Yellow/Purple) cable is missing in my Trooper SE. The manual states 2 Power LED connections, 1 is 2 pin, the other 3 Pin, and both are missing. The "CI" connector is also missing. Also there is a strange 2 pin unlabeled plug (photo attached) that does not seem to have a place to plug into inside the chassis or on the motherboard. Instructions are nondescript. The 2 pin cable for sure goes to the top control panel board above the X-dock. Any help is appreciated.
I left it disconnected. All fans in the case work. So this must be for additional fans only. The front panel works fine. I never found the LED Power connections (Item 12) in User's Manual, but they all work. So we're good.
