Adalbert Németh
MF120R vs Masterfan Pro 120 Air Balance?
I was wondering what's the difference and the reason behind nearly double the price of the pro, when it has lower max RPM (thus CFM) and while the MF120R has higher noise rating, +700 RPM explains that pretty well. Right now I have MF121Ls and while they should be quiet also, they have this annoying "purring" kinda sound that fans do when they have a small wiggle room. I'm fine with the noise of fans pushing air, but this is really annoying and I'm wondering, if more expensive fans would eliminate this, or it's just CM's general idea of "quiet"?
http://www.coolermaster.com/cooling/case-fan/masterfan-pro-120-ab-rgb/
http://www.coolermaster.com/cooling/case-fan/masterfan-mf120r-rgb/
