theanalyzer
ARGB Mini controller USB connection
theanalyzer    2
I got the Coolermaster ARGB 3 fan pack with the mini ARGB controller.
Then later I found out my motherboard does not have the ARGB header (lol).
But there is a mini-usb port which the controller video shows : https://youtu.be/q3M67uC47zo?t=53
This wire is not included in the box, and the video shows the guy connecting the mini-USB to USB and then the USB to the motherboard USB header.
Question is - if I set this up, will the Masterplus software detect it? http://www.coolermaster.com/microsite/masterplus/intro.html
And why wasnt this cable included in the first place?
theanalyzer    2
I connected the mini USB to my USB port and this showed up:
And the controller is unable to change the colors of the fan through the software :(
Sad, because the manual said "download fan software" from the website....
Feeling cheated...
  • Like 1
Julian    0
On 4/19/2019 at 9:39 AM, Willy Creemers said:
https://coolermaster.egnyte.com/dl/Euit8tHb4L
that one worked for my mini controller
Hey is there a way to reverse this because now it keeps on showing up as the RGB LED Controller and it won't work. I found a way to use the Mini through software but I can't revert it.
Julian    0
Feeling cheated...
How did you get that to show up, I couldn't, it only shows up as the rgb led controller and i want it to show up as the argb mini controller
Ph0b0x    0
I have a similar problem. The mini controller shows up on MasterPlus but i need to use the "big" controller that came with the AIO since i have 5 fans and the pump. Any help? Firmware link does not seems to work. This is the controller i am talking:
