Steve
Cooler Master - N400 ATX Mid Tower Case
Steve    0
Wondering if anyone has experience with this particular case AND MOBOs that have their SATA connections on the side. From some reviews of the case, it sounds like MOBOs with side SATA connections are either almost impossible of one has to use an L SATA cable which would then negate 3 of the 6 SATA connections?
In addition the MOBO below also has the Pre-mounted I/O shield.  Any known concerns with this case and MOBOs that have this?
The MOBO I am purchasing is ASUS ROG STRIX B450-F GAMING AM4 AMD B450 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
Reason also for looking at this case is the multiple external SATA connections in the front of the case and cost.
Thank you very much
Stevelsd
