David Anchondo
CM Storm Stryker 3.5" cage replacement
Hello, everyone I have recently got some new fans in order to increase the air flow inside my cm storm stryker. However, I was following a set up by another user link: https://pcpartpicker.com/forums/topic/22606-fans-for-cm-storm-trooper-stryker -- and I read at the very bottom that i would need a third 3.5" HDD cage for the third fan for the front. I have already contacted cm support and they said they had discontinued making the cages for older cases. Any idea on how i could get the third fan on without the 3.5" HDD cage?
