Manuel
CM Connect software does not save settings
Manuel    10
Every time I restart the Windows application "CM Connect" I select the "Default" profile and the fans make a lot of noise. I select "Silent" or any other profile and at the next reboot the device loses the configuration again and "Default" is selected again
  • Like 1
Ilgam    4
I confirm this. After updating windows 10 to october update CM Connect does not apply settings on startup. It seems this software is not supported as it should be. So disappointing.
  • Upvote 1
Manuel    10
The months pass and we continue the same. Every time I turn on my computer it sounds like it was a cheap computer manufactured 15 years ago. This is a real shame. How can you ignore your clients in this way?
  • Like 1
