Ronald Schechter
ML240L RGB Pump Connector for asus rog zenith TR4 motherboard (where to connect)
Hi
  Installed ML240l rgb on Asus ROG Zenith Extreme motherboard.  The pump connector cable has 3 pins,  Trying to determine where to connect it on the motherboard.  All fan connections on motherboard are 4 pin.  The only 3 pin is a water in and out, 3-Pin W_Flow.
Thanks in advance for the help.
Ron
  • Upvote 1
