Kenneth Godfrey
H500M Top Mount 280mm AIO Rad wont fit!!!
Building a new gaming rig.
halfway through my build Im finding out the the H500M case is not compatible with a top mount 280mm AIO.
My motherboard heatsink is preventing the radiator from being installed.
Asus ROG Strix Z390-E motherboard
Corsair Hydro Series H115i RGB PLATINUM 280mm Liquid CPU Cooler
I am so pissed I could spit fire, why would CM say its compatible when it is clearly NOT!
see pics
Anyone else have this issue, if so what did you do?
Edited by Kenneth Godfrey
POCKATA    0
Why are you mounting the AIO like this. Just mount the radiator fans on top of the radiator (on the other side of the case chassis)
Asryan    0
had the same issue, always had my fans below the radiator but I had to change it. But now i'm not sure I should keep them on exhaust and not change to intake so they can blow through the rad?
