Tommy
MB530P Air Flow and Fan help
Tommy    0
Is there a way to control the fan speeds? I don't think I can connect them to motherboard other than using the usb header? Just wondering also at what rpm do they operate on their own?
And any tips for airflow with this case?
Which way should my psu be pointing?
Edited by Tommy
I have pointed down psu's fan and it's fine. And u should connect fans to the splitter and splitter to the desk to some SYS_FAN. With MB530P is included just splitter to the psu, not to mobo so you should buy if you wanna control it.
  • Upvote 2
