Simone
MasterLiquid Lite 240 Watery noise
Simone    0
Hi, i just got my MasterLiquid Lite 240, the AIO is awesome but it makes a watery noise, a couple of times in a minute, it's been a couple of hours now and i tried tilting the case over multiple times as was suggested by users in the forum. Is it normal? I'm worried that it could cause a leak, it's my first time with an AIO so i'm a bit worried. Thank you!
It shouldn't leak when moving it around unless you are trying to rotate the hoses on their connectors. I have heard to put the sealed end of the radiator higher than the rest, and if possible put it above the pump. Has this been resolved yet?
Simone    0
Hi, sorry for the late answer but time was passing and i thought nobody would respond. Btw i mounted the radiator in the front as intake, the sealed end is on the bottom, so that should be the problem? Because it still makes that noise every 10/15 minutes.
