Yang
C700M Front LED Problem
neno    4
12 hours ago, Genma said:
I received the new pcb and I installed it. Everything finally works correctly! The new pcb is different from the old one: there is two connector for SATA power.
I ask Cooler Master to make a small gesture to compensate for all these problems, I await their answer.
Good luck to those who still have the problem. In the end three pieces must be changed to solve the problem: the front panel, the top and the pcb.
Can you post the picture of the new PCB, I would like to see all the differences between old and the new one? I still have the old one but its starting to act funny, occasionally (around twice a week) upper top right LED strip goes to trough the cycle of changing colors. So I'm waiting to go completely broke so I can ask for RMA.
C700M    0
Hello,
I am Japanese. I use translation software because I am not good at English.
March 20
 Coolermaster informs you that it will be repaired.
April 3
  bottom RGB confirmation question
The rest is left untouched.
Edited by C700M
neno    4
Well I got today my replacement parts, PCB and top panel. The new PCB is the old model with molex connector, the same as the one currently in the case. Who knows if this one will go broke just like the old one. The old one went broke after 5-6 months.
So yah my ticket was closed by the system with the message "your on the list when parts come in" that was on 4/4 ... still no sign of parts.. Thinking now I should have went with the 1000D or the Phanteks option.. Live and Learn I guess
neno    4
Did you try opening another ticket? I've opened my ticket on 25th of April and they've sent me replacement parts on 29th, so maybe they've "lost" yours. But there is obviously a problem with the argb controller even after changing the PCB layout.
No, not till just now.. was taking them at their word that they where waiting for parts..
We shall see what happens with this ticket.. it should not be that hard for them to get a working controller thrown together.. the thing is which is the actual "working controller" the single Sata? dual Sata or single Molex powered board?
Deniz Roth    2
Well they changed all parts of the case u need a new Front Panel, top panel and a new pcb with 2 sata Input. After changing all it works for me. Took 1 month for because they sent all one by one Tell Them they should Send all :)
Edited by Deniz Roth
Hey guys! I’ve bought mine on 28/03 and have experienced the same issues as all of you, top led going bananas, front leds not working at all, etc. I never contacted support as I could settle for a case without led by just turning them entirely off. But yesterday the PCB got a small fire and had a small explosion (like a gunshot sound). I highly recommend not buying this case and I am going to leave some reviews around the web.  Do you know if I can “wire” the connections plugged through PCB directly to MB? If yes is there a scheme?
And here is the sign of the small fire on the case “door” cover:
Edited by LuckyFox
