Yang
C700M Front LED Problem
Genma    0
Posted (edited)
Today I received the replacement kit for the top panel. After mounting, I see that the LEDs of the new kit do not work: I check the connection cable, and it has only two pins while the same cable on the old kit had 3 pins....
Edited by Genma
Deniz Roth    2
i have the same problem. have got a new one or what did u to solve this?
Genma    0
Posted (edited)
Following this problem, I contacted the support who sent me a new kit for the front panel. Connectivity has been changed on the new kits, and now the top panel connects directly to the front panel. (a new connector with the two pins is present) Part of my original problem is fixed: the LEDs change color well without problem even for a long time. Unfortunately the new kit from the top is defective, some LEDs do not work ...
Edited by Genma
Deniz Roth    2
no i have now the same problem like u i think its a controller problem the leds works well with Asus Aura Sync over the mainboard
Deniz Roth    2
What did they do now? i have the same problem
Genma    0
The support had sent me another controller card, I tested, the problem is still present. so he sends me a new kit for the top again.
Deniz Roth    2
If i use mainboard Sync (Asus Aura) it works but with the i/o Buttons it dont work... wasting a lot of Time....
